Bearing buddies keep falling off...
bruceb58
Re: Bearing buddies keep falling off...
The best way to adjust the bearing nut is to tighten it while spinning the wheel...some say around 20 ft lbs. Then back off the nut and then just hand tighten it liniing up the cotter with the closest notch or hole depending on what you have. There should be little or no play when you shake the wheel.
82RAYSONCRAFT
It's called Loctite. I us it all the time at work for worn/lose shafts, bearings, ect.
Retaining Compounds
For nonthreaded metal cylindrical parts such as shafts, hubs, bearings, bushings, splines, and pulleys. They prevent corrosion and fluid leakage between surfaces, resist most chemicals, allow reuse of slightly worn parts, and provide better strength than shrink-fit and press-fit assemblies. Come in bottles.
603?? High strength and contaminant resistant. Fills spaces up to 0.005" dia.
609?? High strength and low viscosity (125 cp). Fills spaces up to 0.005" dia.
620?? High strength, high viscosity (8500 cp), and high temperature. Fills spaces up to 0.015" dia.
638?? Maximum strength. Fills spaces up to 0.015" dia.
648?? High strength. Fills spaces up to 0.006" dia.
680?? High strength and medium viscosity (1250 cp). Fills spaces up to 0.015" dia. NSF/ANSI-61 certified for use with drinking water systems.
Threadlocker Stick Adhesives
Same performance as our other threadlockers, but in a convenient stick form. Begin to harden in 10 min. Max. temperature is 300? F.
248?? Medium strength for 1/4" to 3/4" dia. fasteners. Color is blue.
268?? High strength for heavy duty applications on fasteners up to 3/4" dia. Color is red.
jdt
I Am going to sound really stupid here but I know I have bearing buddies on my trailer, however how much grease do you put in and how do you know when enough is enough? :confused: I recently aquired my first boat and trailer.
bruceb58
Pump until you just see the piston moving. If there is an air pocket, it may work its way out and you will have to add a little more.
jtexas
yup...push on the pressure plate with your finger - if it "gives" at all, then add no grease, if it doesn't, add just to enough make it move.
