astronutski
Thread starter- Joined
- Jun 21, 2016
- 78
Hey guys, I've got at least one possibly two dumb questions, which will consume my allotment for the year ;-)
1986 Alpha 1 gen 1, I've replaced the water pump in the gear housing, the upper and lower oil seals in the driveshaft housing, left off the Drive Shaft O-ring and installed the large O-ring on the U-joint "stack". But it failed the pressure test miserably, as in, I couldn't get any air to hold, it would come out just as fast as I pumped it in by hand, I needed a second person to spray the soapy water. I am convinced it is coming from the inside of that bearing retainer ring, the 200 ft.lb. castle nut. Not from the thread area, I've torqued that to 200 (using the chart and a 1/2" click torque wrench), but on the inside of that, so I'm thinking the problem is the oil seal #29 on pg 51 in the manual which came in the rebuild kit but I didn't install because of bearing preload issues. (not sure if my link to diagram in manual is working, but it's the link (I think) Chris posted at boatinfo.no)
Dumb question #1: Do I have to set the preload if I remove that nut to replace the oil seal only without touching the bearings? I see there is a preload spec in the manual for used bearings, so I'm thinking once you remove that nut you're not getting out without setting preload either way.
Intelligent question #1: Does this air leak area point to that oil seal in the bearing stack? I can't think of anything else there that could be the culprit.
(In typing all of this I figured out the answer to my second dumb question, so I still have one in the tank for later)
