Bearing removal???
nofishjoe
How in god's name can a person remove a bearing off a prop shaft? An easy way or a hard way. I amnot caring... How do I just get it off. Please and thank you for all who respond to my plea for help
petryshyn
Re: Bearing removal???
Me tinks we need more info on dah engine you have.....
nofishjoe
Me tinks the eninge is a piece of junk.... Considering it be like eh 30 years old. The enigne is a scott McCulough 1969 45 horse. Told ya she was old.<br />Justtryign to make it work again before I am forced to have a funeral for the old beauty.
mrm
Me tinks a manuel would help, more than anyone on this forum could. ( unless they would come do it for u ) - Look up- Try the helpful links [ manuals ]<br /> Good Luck @ Have Fun<br /> MRM
mrm
But in general, you would use a bearing puller.
FlyBoyMark
Ensign
Get a die grinder with a cutoff wheel and cut it off silly boys....if ya score the shaft a "tiny" bit length wise ,this will hurt nothing. Should take less than two minutes to do it. Cut one side only and drive a small screw driver in the cut and remove
nofishjoe
Die grinder and cut off wheel????? Well these things I do not have and well hey I think it would be cheaper to go get a gear puller.....But hey.. would that work?
nofishjoe
and what is the difference between a gear puller and just trying to grab it with a channel locks and pulling like hades...besides I am afraid by using a gear puller might break something. Som one please tell me different
Just because it's old doesn't mean it's worn out. just increase the chances
FlyBoyMark
Ensign
Do you have a skill saw, use a cutoff wheel in it, jus' be care full
FlyBoyMark
Ensign
If ya have a bench vise open it enough to slip the shaft in between the jaws and pound on the end with either a piece of aluminum or copper between the hammer and end of the shaft. Might try heating the bearing only with a propane torch jus before ya pound on it.
