bedlined trailer??
kdgncop
has anyone herculined or like materialed an entire trailer?? instead of taking my boat of the trailer to paint the trailer, i thought it might easier to just roll on some bedliner. the trailer is white, so i was thinking about gettin the white roll/brush on bedliner for the entire trailer, and then on the back corners or steps where it is carpeted, to just roll on some black there and the little corners in front of the fenders. anyone done a similar project at all?? pics of the white bedliner on a trailer by chance?? any pics at all??!! also, how well do decals stick to the bedliner products?? do they at all??
Bob_VT
Re: bedlined trailer??
Welcome to the iboats board!<br /><br />Nothing (decals) will stick to the bedliner coating. It does stick on brake springs but I would just suggest paint. Paint is much cheaper and lasts quite a long time. Get a good enamal paint and roll it on. If you are trying to treat rust be sure to sand it down first.<br /><br />Bob
Ayuh,........ What Bob Says........<br /><br />I prefer Rustolium........ Lasts Forever,.. as long as you properly Prep the base metals.......
craze1cars
I paint cars at times, might be able to help with this one.<br /><br />If you want quality, you gotta look WAY past your local auto parts store and/or hardware store if you want gravel road chip protection. Nothing they can provide will do the trick, short of such a "bedliner" coat job, which in my opinion will end up looking 10 times worse than a chipped up old trailer. And then you'll hate the results, you'll want to remove the stuff and start over, and THAT's when the REAL headaches start.<br /><br />Professional paint venders (Finishmaster, DuPont, Sikkins, Glasurit, etc) all sell their own version of "gravel guard," and this is what you want if you can swallow the cost. Usually involves first sanding/deglossing the original paint and removing all rust. Then a self-etching primer over any bare metal, then a base color coat, then a "gravel guard" type of clearcoat. Some systems put the gravel guard coat under the color coat and then a flex additive is put in the color and clear coats. Either way the end result is basically what you see down on the rocker panels of many new cars today...an orange-peely, glossy, and almost indestructible finish. And decals will stick perfectly.<br /><br />It takes a lot of prep and a lot of money, and can only be laid down with a HVLP sparygun ($150 for a cheap one) pushed by a compresser that puts out some serious CFM at low pressure (220V, 60 gallons plus, big floor-standing type of machine). Prepare yourself for sticker shock if you decide to buy such a paint system, likely will burn up close to $400 in paint materials alone to do a typical boat trailer, but it'll look beautiful and will last forever. You might find a body shop that's hungry for work willing to shoot the trailer for you somewhat reasonably if you strip it down and do all the prep work.<br /><br />For most people with old boats/old trailers who are not independantly wealthy, I agree that a bomb can of Rustoleum regularly applied is by far the most economical and acceptable looking option.
dajohnson53
I find that paint, no matter what the prep or quality, doesn't hold up at all, not even two seasons, if you spend any time on gravel roads. I really like the general bedliner idea- something that will resist chipping by graveln- maybe just on the leading surfaces? I hope the discussion goes on because I'm curious if anyone has done this in some form.
OBJ
Now that, was some interesting info.....thanks cars..... :)
gewf631
I picked up some Herculiner at Menards last year ($45), and painted my trailer. My prep was to sand the worst rust, a quick pressure-wash and then a wipe-down.<br /><br />Is it all shiny and new? NO<br /><br />Is it durable? So far, so good.<br /><br />Would I do it again? You bet!<br /><br />I especially like the non-skid finish.
nektwister
a very good paint is dura clad or sherwin williams dtm direct to metal just for general knowlegde
Mybigjohnson
If your looking for really tough paint might I suggest POR15. This stuff is as hard as a rock. All you have to do is scrape off the loose rust or sandblast then paint it on. POR15 actually dries faster the more humid it is. This material is a rust converter and paint all in one. I painted a small utility trailer after sandblasting it and this stuff is great. <br />Check it out. The Minn Dept. of Transportation uses it to paint their vehicles.
