been a while but i'm back
Kohrah
After my grandpa pasted away i entered into a funk and a didnt want to do anything. Than with the current economy my dad lost a number jobs over the last year and a half. So i was sole bread winner of the family. So the boat took a back seat and stayed layed up un the barn.
My dad and myself have both found stable jobs again so i have begun working on my baby again.
New gearcase, coils, and the lot was done before the soft brown stuff hit the round spinny thingy. Just out a new prop shaft in yesterday as the old one got bent in storage. (Moving boat around to store vehicles and slammed into a short pole in the barn), new seals. Hooked all the electeical back up after checking all the wires. Checked steering cable and while showing signs of age it is still intact.
Now i just need a new battery, gear oil, amd fuel lines.
Mel Taylor
Re: been a while but i'm back
Kohrah,
Welcome back. Sorry about the loss of your grandpa. I remembered your handle but I had to go back and look at your old posts before I could remember what kind of boat you were working on and what, exactly, you were doing to it. How 'bout posting a summary of what you have done so far? And be sure to mention the kind and size of boat. Some pics might be helpful also.
Kohrah
Thanks mel,
The boat is a 1962 Lonestar Biscayne 16' runabout with the orginal 1962 75hp johnson outboard engine.
Parts added / projects completed:
New gearcase
New shift coils
new prop shaft
New cooling pipes
New shift wiring harness
new seals
New water pump
Sorted out electrical wiring
replaced any bad wires
cleaned carbs and fuel filter
New bearings in gearcase
new motor mounts
Projects to be completed:
Test run engine in tub of water to test functionality
tune carbs
Projects to be completed as able:
(Aka not nessecary for functioning boat)
Repair/replace seats
replace canvas top
Run new steering wire
Paint engine and re-decal to original colors
restore gelcoat color with proper buffing/waxing
Pictures will have to wait or else can pull up old threads of mine to see.
