Bell Housing Shift Lever
1960 Starflite
1979 Century 190, Mercruiser 140, Stern SN 5163321
I have the entire bell housing off for bellows, gimbal bearing and shift cable replacement. I thought I'd remove the shift shaft lever, as the replacement shift cable (purchased here) kit has a new one.
I understand that OEM used locktite to hold the screw. Manual states "use caution when heating lever to release bond" or something like that. I heated it with propane torch, but not much, didn't want to ruin seal. How much heat does it take to release the locktite? I do have an oxy/act torch set, really don't want to go there.
Does the Sierra bushing kit 18-2622 fit my drive? Drives are so confusing, Mine is an MC-1, I think :joyous:
Thanks in advance, Great Forum,
Bt Doctur
drill a hole near the pin and just break the arm off then remove the pin
achris
More fish than mountain goat
That serial number, yes, it's an MC1, a 'later' one. (has trim sender and switch on the gimbal ring)...
Before breaking or heating anything, just give trying to unscrew the pin a go. I have found they usually screw out without too much problem.
And yes, that is the right kit.
Chris.........
1960 Starflite
Thanks for the responses. I ground a screwdriver to fit screw tightly, didn't budge after gentle propane torch applied.
I then drilled two 1/4" holes approximately 180 degrees apart, two wacks with cold chisel & ball peen hammer it broke apart. All is well 😊.
Thanks for confirming on bushing kit #
This forum Rocks. It's helped on my 300 & 850 Mercs also.
