Scott06
- Joined
- Apr 20, 2014
- 6,881
2004 Merc 5.0 Alpha gen 2 (outdrive/Transom Serials OM491962/OM847410)
Going to replace my bellows this weekend, all original rubber- exhaust bellows gone, driveshaft bellows is good shape except for chaffing on side that I understand are from too long hinge pins. Have all OEM parts including shift cable and tools on hand
A couple questions-
A couple questions-
- I'm a very experienced home mechanic and experienced on mercruisers maintaining boats for last 35 years. How long should I expect this job to take (Freshwater boat)?
- How long do you need to let the bellow adhesive set up before splashing the boat? I figured over night given 65-70 degree weather?
- The boat shifts perfectly so I was thinking of not messing with shift cable but I do want to replace shift bellows- reading through the factory manual it wasn't 100% clear what to do with shift cable - you disconnect if from bellhousing and pull it through- basically completely remove it from boat? If I do that I might as well replace it? Wasn't sure if there was a way to leave it in?
- Continuity I have a little bit of corrosion around the prop (revolution 4) and wanted to verify the continuity straps are ok - I assume I could check from the inner transom plate to the drive or lower unit to see if it is ok? Is there an ohm reading that is considered ok?
