bellows caught in the moment
leeann4
merc.260 alpha one. Installed new bellows this weekend went great*&%^$(.when bellows were installed looked at friend and relized didnt put glue on all ends of bellows. from the pros. will i be ok without glue, clamp is on the way it should be.or should i go threw the pain again.
mkast
Re: bellows caught in the moment
No<br />Yes
I/O WALDO
If the clamps r on correctly,SHOULD bee fine.(opinion)
mike456
Why would you wnat to ruin your boating fun by always wondering if it might be leaking? An why risk a big money repair. Suck it up and spend the time to re-do it.
I got a $20. that says it'll Leak............
Bt Doctur
not to mention a new gimbal bearing, corrosion from water where the boot clamps on,(lose that flange, lose the transom assembly.or a simple SINKING.
HT32BSX115
I would R&R the drive/bellows.<br /><br />The good side is....you're "experienced" now in the replacement! It will go a little quicker than before. :mad: <br /><br />A little pain now is better than a LOT of pain later!<br /><br /><br />Cheers, <br /><br />Rick<br /> <br /><br /><br />
Originally posted by leeann4:<br /> merc.260 alpha one. Installed new bellows this weekend went great*&%^$(.when bellows were installed looked at friend and relized didnt put glue on all ends of bellows. from the pros. will i be ok without glue, clamp is on the way it should be.or should i go threw the pain again.
