gerrydoc826
Thread starter- Joined
- Jan 12, 2025
- 4
What's the average cost to have all the Bellows replaced. I have a Tahoe 2018 500 TS with the alpha 1 Merc outdrive
Would think a grand plus of minus a few hundred depending on where u are . Saw you comments In other post On lifespan.… use OEM parts in fresh water my u joint bellows were just starting to crack after 18 years .What's the average cost to have all the Bellows replaced. I have a Tahoe 2018 500 TS with the alpha 1 Merc outdrive
Does seem odd but may be influenced by water quality. I believe in salt or brackish they don't last as long. How were yours torn?Thanks for your reply. I wouldn't think mine would be worn out after just 5 years only having the boat in the water for 6 months out of the air and maybe using at 12 times a year. Of boaters whose have lasted anywhere from 10 to 20 years. Again thank you
for all I have read about it here and other forums have not had an issue.Driving around a lot in shallow water with the drive tilted up a lot. Is tough to.
