Plotus
- Joined
- Aug 15, 2010
- 23
Thanks to
Marvinjansen
for this pic on his post But if you see through the gunk, on the slide to the left end is a boss and directly below, a ? set screw? Is it a set screw? does it turn to the left to loosen? Also as for changing the Bellows on the Alpha1, do the bellows tool actually help much? I'm finding stories of little alternate stuff for working on these boats instead of special tools. I don't mind having to get a couple things like an alignment tool or a bellows tool or the Mac flex driver, but I just learned that the pivot was just a 1/2" allen wrench rather than the special tool. So guys, those of you who have changed the bellows..... how usefull is the bellows tool? Fortunatly when I pulled my out drive there was only broken wire, the bellows had only a half inch rip in the seam which would only leak on left turns, and only a tiny bit at that. So my gimbal and joints were pretty nice, without any apreciable rust at all on the gimbal and the joints perfect. One thing though, that dang slide's being a dadgum errrr........... trying to get the set screw to loosen......
