FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
does anyone do this? this boat has always tended to run a little hot at low rpm and i keep it in the water most of the time so changing the impeller is a bit of extra work.
Yes either a belt or crank driven pump can easily be installed. I set one up for a guy and used the pump in the drive just for the P/S and engine oil cooler. 'nutcase
I did the same on my setup - the engine had a belt driven pump and I installed a 1.25" thru hull fitting with a strainer. The hose from the outdrive I simply re-routed back through the transom with another fitting. To flush I would use both muffs and a hose in the strainer. Here's a couple pics:
It is a pretty small hose that you would have to pull through - I would go with the thru hull fitting with a seacock valve. More volume of water and more efficient cooling.
