Ben's - 1992 14' Ashcraft Budget Flats Boat Build.
Amsoil Man
Hey everyone, New to Iboats.com and just wanted to show off my new vessel. I am thrilled to finally be a boat owner (I previously owned a stand up jetski but its not the same). To start off I purchased the boat through craigslist. The guy I bought it from originally wanted $1500 but I lucked out and got it for $1000 including the rusty trailer and a depth finder :p . The patients paid off big time because I was about to pull the trigger a week eariler on a 15'6" Key Largo hull but I know I would have been dissapointed. Every minute I have off from work and school goes into this boat... I got the bug big time. I couldn't be any happier with my progress. This is definitely a budget build because if the money is not going into the boat it is funding college.
As off right now I have put $1903.64 into this boat project (This includes the boat and a new trailer).
Anyways, thanks everyone for looking. I look forward to hearing from everyone and any comments that would be helpful.
Thanks again,
-Ben.
The night I bought the boat:
jspano
Re: Ben's - 1992 14' Ashcraft Budget Flats Boat Build.
good luck!!!
post some pics
Amsoil Man
Dirtbag interior...
Thanks for the words of encouragement :rolleyes:
Amsoil Man
The next morning I scrubbed the paint off of this thing.
The old trailer was way to long so I ended up caddy cornering it that night.
Amsoil Man
I got into the swing of things quickly and installed a tank and goodies.
Amsoil Man
After the tank I started working on little things around deck. Lots of scuffs, dings, and scratches to fill and sand. I patched 5 holes with some epoxy puddy. It worked like magic on 4 of the holes. I didn't quite mix it well enough on the 5th hole and now I have to redo it again (Lots of mold and such in the conpartments).
Amsoil Man
Mom totally delivered this year with her gift (She gathered a bunch of stuff from her work and made a first aid kit. I added a few things). I ended up buying the dry storage box, and deck lines. I had an old fire extinguisher laying around so I added that in as well.
Amsoil Man
I noticed the hole I patched in the front compartment has a pinhole leak of brown water comming out of it so I ended up putting more epoxy puddy over it to stop the leak.
After I sealed the hole I started to polyurathane the inside.
jspano
edit your profile to show where you ar located.
where in fla are you ... new tampa maybe??
Amsoil Man
To my supprise I took a peek in the compartment the next day and found water again inside... I was like what the heck... Another hole magically appeared.
Amsoil Man
I started removing items off of the boat to prep for paint and or to fix. First with the tansom to bow trolling motor mount. Then the pole holders.
Amsoil Man
Since perfection is my middle name I home in on things that are poorly slapped together. Here is the refurbished tansom to bow trolling motor mount (New screws included). I sanded the whole thing and found out that is was infact fiberglass so I started icthing. Counter sunk the screw holes and lined everything back up straight as could be. I was happy with the end result.
Amsoil Man
It started to get rather chilly around here in Florida so I turned this into winter built (Now it is heating up and I dont have a ice chest to sit on anymore :confused:) Not thinking the weather was going to heat up any time soon I started planning for a new seat install.
Started sanding after I got the baseplate off.... It was really sealed on there good.
Got the dremel tool out for the bow of the boat.
Amsoil Man
I got really anal and started marking every imperfection I could find on the deck. Every nook and cranny was inspected and marked with a sharpie.
pmillar
Looks like good progress. I hope none of the holes you plugged were designed to drain any of the compartments. :confused:
Amsoil Man
The fiberglass glob on the front of the boat was making me lose sleep so I cleaned it up and preped it for re-bracing. You could imagine the retarded mess I found underneith. What in the heck was someone thinking putting that sliver of wood in there and expecting it to hold.
Amsoil Man
I started slapping puddy on the deck like a mad man after I used the dremel. The next day it was dry and I started to sand the entire deck. It turned out way better then I expected.
Desided to put some on here too.
And what do ya know - A leak again... What the heck is with these mystery leaks.
Amsoil Man
I called it a day today and finished up sanding. The sperrys had seen better days. I also started doing a little paint. Results where very nice.
Amsoil Man
I have a bunch more things on my to do list including a new seat and a few other one off parts. I haven't ran into any huge snags yet so lets pray everything goes flawlessly. I should be updating my thread every couple days or so -- Keep posted.
Thanks again,
-Ben.
Amsoil Man
Will do chief - I'm currently in Orlando Florida. (Winter Garden if you are a local :) )
Drain Smasmain - Haha. I'm going to hacth everything off when I order one. The holes that where there for drainage actually held water instead of draining it. So I ended up sealing them :p
