Bent Bow Rail
Joker757
In one of the hurricanes a few years back the starboard side of the bow rail got pushed up (see pic). Any suggestions to fix this? Can I just bend it back?
jonesg
Re: Bent Bow Rail
Try sticking a 2x4 through it and bending it back. Use your weight rather than strength.
Joker757
Re: Bent Bow Rail
are you saying to insert a 2x4 running across the bow under the port side of the rail and over the top of the starboard side?
jonesg
Re: Bent Bow Rail
Exactly, thats all a boatyard would do, then give you some yarn about a special jig.
Yacht Dr.
Re: Bent Bow Rail
I might have a better screen then jones ;) ..
Looking like your replacing that puppy to get it right.
Its not just your port side..but your stbd side is whacked out too ( from your pic ).
You also need to rebed All of those through bolts no matter if you take a 2x to it or not..
Got insurance ? ..
YD.
PS. I dont see any way to fix an outward streach/bend of tubed SS .. Inward bend possible..not outward. Very hard no matter what.
Joker757
Re: Bent Bow Rail
do I just replace the risers (deck to rail) pieces or the rail as well. Planned on using Interlux 214 bedding compound.
