Bent prop shaft...worth fixing or new lower?
jthor3277
Hey guys. My bud bent his prop shaft this weekend and I was just wondering if it's worth re-doing the prop shaft or just replacing the lower? I have some of the special tools to do it minus the shimming tools. Is this a big job and is it that's worth it? Thanks
Mercruiser 4.3L V6
Alpha one Gen 2 (1.81)
achris
More fish than mountain goat
Re: Bent prop shaft...worth fixing or new lower?
How bent? More than about 0.1" is too much (that's most I have successfully straightened)... And when you straighten it, it's got to be better than 6 thou... Even if you put a new propshaft in, you won't need to reshim...
Chris.......
Don S
A new (Aftermarket) propshaft is $515 from here at iboats, the SEI aftermarket lower unit with a 3 year warranty is $835
jthor3277
Chris.......
Hmm I never even though about straightening it. I'll get the numbers today and see just how badly it's bent. What's your process for straightening it? Thanks for the reply.
Thanks Don. I was just wondering if the schimming process is a bear and labor intensive to replace. But mostly, just want to do it right.
achris
Vee blocks, a press and a dial gauge.
As I said, it doesn't need to be reshimmed for a new propshaft.... And even if it did, the shimming process it not difficult, just a bit fiddly... and you need the right tools... which you don't... :facepalm:
(Now I'm confused :D)
Chris....
jthor3277
You're right Chris I don't have the merc shimming tool and it's nice to know that you don't have to shim the new prop shaft. But i do have the dial indicator setup and did a runout this morning of the prop shaft. He hit something good with a .750th of an inch deflection. It was a stainless prop on a gen 2. With that big of a deflection, should I be worried about the drive shaft and upper? The boat does vibrate.
Ayuh,.... I hope ya missed a decimal point there, that's 3/4"....
The price of SEI lowers beats rebuildin' what ya got....
