Best Battery Selector Switch?
DC20
My Perko 2 Battery Switch has water in it. Is there a better choice, Guest,Attwood... ?
grouper21797
Re: Best Battery Selector Switch?
My preference is Guest. It is well constructed. I 'stupidly' reversed the cables on my battery when I re-installed it. When I switched to that battery there were fireworks that came out of the switch. Blew a few fuses in the motor, but after replacing those, everything worked fine. An inspection of the switch was good. I still opted to replace it and after much research decided to replace it with another Guest switch. The best over-all price was found at... http://boatersland.com/ . You will also come across with or without AFD; you either need it or you don't and most outboards don't, at least not mine. So don't think it is something better because it costs a few dollars more. It took forever to discover this.
