Best Guess: Carb Rebuild Needed?
Yachtsman1304
1997 Mercruiser (Mercab 2bbl), TB 5 ignition, 4.3 LX
Ok....here it is. Let's see if I have learned anything.
Problem:
After a 10 minute run today (varied between 3/4 and WOT) when I brought it back to idle it would not idle. If I kept it above 2000 or gassed it it would keep running. Changed fuel/water separator and got it running enough to get back to the dock. It ran on plane just fine...no stumble nothing. When I brought it back to idle at the dock it would idle, but as soon as I gave it gas (from neutral) it sputtered, but would keep running after a hesistation.
New plugs about 10 hrs ago....I am on the bottom half of a fresh tank of fuel (ethanol treatment added). New fuel pump within last 20 hrs....Temp is good, voltage is good, oil pressue is good, oil level is good and clean.
I am guessing I need a carb rebuilt and that my float is gummed or my "idle circuit" is messed up (whatever that is).
Am I on the right path?
Thanks!
sltintexas
Re: Best Guess: Carb Rebuild Needed?
those were my symptoms when I did my rebuild.
achris
More fish than mountain goat
That's where I'd start..... You did check compression?
Yachtsman1304
Compression was good when it was checked last spring. Timing was checked and found to be fine too. I noticed several times this season it would start awesome, idle well cold, I would run it...then sometimes it would surge at idle after a run...and other times it ran like a watch. It seems to always have its issue after I run it for a bit (10 mins on plane). The issue until today was just a surge of idle RPM of 200 or so. The more and more I think about it and talk about it, my carb must be loaded with trash.
achris
An intermittent problem like that does sound like dirt in the carb....
franktrav
i would inspect for a vaccum leak. check around the carb and intake for a hissing sound . sounds like it is sucking air to me
