Best oil and plugs
ralphl
I'm a long way from a Suzuki dealer, but I do have a NAPA auto parts store. What is the best 2-stroke oil for my DT55? And, if I can't find NGKB (R) 8HS spark plugs, what would be the best replacement brand that NAPA carries to keep as spares?
Thanks,
Ralph
robert graham
Re: Best oil and plugs
You can buy the correct NGK plugs on line and delivered directly to you in about 2 days, so no need to experiment with "other" plugs. I run the Pennzoil 100% Synthetic Outboard Oil (Walmart $27/gallon), pretty hard to beat. While you're at Walmart pick up some Stabil Marine($20/quart), and a fuel/water seperator($28), easy to install, great preventive maintenance. Good Luck!
