Re: Best old 35-40hp motor to look for.
Those came either way. That was the year on that particular motor, where the fuel pump was available as an option. The best way to tell, is to look at the fuel line connection on the motor, which in your picture, is between your throttle cable hookup and the throttle speed indicator. The pressure type system will have two hoses going to it and the fuel pump model will have a single hose. I do see two holes in your lower shroud, behind the fuel connector, so it's likely the pressure type system. If the tank is available, be sure that it isn't rusted out and it works properly. If not, then it would be simpler to convert it to the fuel pump system, than to scout out a good replacement tank. That model also came stock with a rebuildable fuel pump, but you can also convert it to a later style fuel pump, from a later 28 or 33hp motor. Your upper bypass cover should have the bosses molded in the casting, so you can remove it and drill the holes to accept the fuel pump.
