Best Prop merc black max 150
legoman67
17.5ft Canaventure with 1989 150 black max merc, it currently has a highfive 21p prop, which is great for high speed, but we want a little more torque/power for pulling skiier's out of the water. any suggestions?
j_martin
Re: Best Prop merc black max 150
That setup should durn near tear the arms off'n a skier. I'd suggest checking your setup and operation. The engine should be brought full in for a hole shot. On most setups that will actually bring it to negative trim, and put the stern on top almost immediately.
I'm assuming the high five is vented. If it isn't, have a prop shop put some vents in it. On hole shot, the engine should spool up to about 3 grand instantly. If it balks, you could have a tune problem. If it idles fine, check the linkage and timing adjustments (link-n-sync). They need to be spot on for a good take off.
hope it helps
john
