Best rod holders
tpcowfish
Hey, There may be some post on this, but I want to get updated opinions on the best rod holders for a open bow fishn boat. Maybe even some ideas to rig my own, Looking for easy to use good, versitle, mobile, like a system can be moved for different situations without a lot of re riggin. Mostly fish Lake Erie, but like to travel a little , Stripers(landlocked) and Bass. I had a treated board across back on old boat , i could take on and off, for trolling. Just lookin for some Ideas, U never know what u can learn from others, Thanks, Tim
Hoopie
Re: Best rod holders
I would say double action monster rod holders or driftmaters.
tpcowfish
Re: Down East rod holders
These are my favorite as well, although the folbe seems to have some of the nice features of the Down East rod holder.
They look good, do you know if they work on a gunnel, I have a wide gunnel ,But I think I could clamp underneath, vertically, Do you have these?
Mark_VTfisherman
I do not use the clamp-on model. Mine are mounted to the vertical inside of the hull cap, which I guess is part of the gunwale on my boat. Looks like
you can see two of my four in this photo That is not me- a fishing buddy with a small Arrowhead Mtn Lake walleye
They bolt or screw on with two screws into the bases. Clamp on idea bothers my mind and it makes me afraid of someone stealing them. They are not expensive but they're not cheap, either.:eek:
tpcowfish
Well i dont troll to much, i like to remove them , or, move them, at will. I use them for walleye after catch. to keep rod safe, or bottom bouncer, jiggin in spring, would like to remove when i bass and put tarp on, or move with different amount of people, , Well thanks all for idea's!
bugman1964
I used the clamp style in my canoe years ago and it worked well. In my boat I ended up mounting them to the angled bracing at the center bench seat. The mounting plate was a little too wide for my gunnel. The downeast does have a tendancy to vibrate and make some noise when under power greater than trolling speed.
recce43
i use scotty rod holders flush mount the pop out then you can put in drink holders anchor lock all kinds of stuff www.scotty.com
ondarvr
Scotty's work well, they also have a Folbe clone.
Mark_VTfisherman
...The downeast does have a tendancy to vibrate and make some noise when under power greater than trolling speed.
Depends on the boat and motor- mine are quiet at speed, but one rattles a little at idle. I bought a bag of 1000 rubber bands on the discount table at the local office supplies store. I drop one in while a rod is out of the holder. Shuts it right up. They are quiet with a rod in the holder too.
The biggest thing for me is that when a fish strikes, all you do is grab the rod and lift- you don't have to release anything or pull the rod forward or anything- your first action is the same movement you would make if you had been holding the rod, got a strike, and lifted to set the hook.
They also are very compact- even the Salty is not very big- 1/3 the bulk of the plastic rod holders.
ondarvr
A buddy has the Down East models on his boat and they work well, I've always been amazed that more people around here don't use them.
Huron Angler
Ebay's got some great deals on flush-mount stainless steel rod holders. I got a pair shipped out 2 for $30. They have rubber inserts and a cap that keeps water out when not in use. I like them:)
Keeps them out of the way but always there when you need them. I'll be adding downriggers w/ rod holders down the road too.
tpcowfish
Did you have to drill big holes in gun wales to fit, R they strong, and how does the cup holders and ect work?
tpcowfish
Oh by the way, Thanks everyone, pickin up some good tips, and photo's
recce43
just small hole or you can get top mounts everthing just slides in and locks in but you are able to putt them in any postion
