Best rust loosening material
The pallets out sheet metal cam on was 8' wide and 20 feet long.
redneck joe
I built ashed out of glass crates when I worked in that industry. Lots of 12 foot2x12, 8s,etc. Pull nails and cut as needed.
bruceb58
Cut them off. I would never use old rusted hardware on something like that. Plus, my time is worth more that spending time trying to get rusted bolts apart. This is why I own a plasma cutter.
Mc Tool
There used to be a vehicle assembly plant in Nelson , all the vehicles came TKD in a galvanised sheet steel crate . There are probly thousands of sheds and fences made out of the sheet , one part of the motorway there was about a mile where there were only a few fences that were not made out of the sheet , the inch angle frame work was dead handy too , not galv tho :)
Mc Tool
. Making roof trusses from nailing pieces of pallet runners together for a long span with used nails doesn't sound like a great idea.
squirt in a bit of builders glue and clamp it up and your gold 😀
airshot
I donno - every truss I've ever seen uses contiguous lengths of wood, not shorter pieces scabbed together with used nails.
Today's trusses yes, but back in early days that is how they came into use.
Didn't really think it needed explaining, but guess I was wrong.
Chris1956
Gee, most of the time the 5/16" ubolts on my trailers just broke, when I tried to remove them. They were galvanized and looked rust free, but they broke, just the same.
The larger ubolts usually came undone w/o breaking.
make sure you have a source for replacements, just in case.
nola mike
It's amazing what some people can do with old pallets. The wife loves pallet wood too. Even she draws the line at reusing nails. I pray I'm never so hard up I can't buy a box of new nails and a contiguous length of varying sizes of wood at least 8' long. Making roof trusses from nailing pieces of pallet runners together for a long span with used nails doesn't sound like a great idea.
I totally reuse nails. And lumber. The sea walls/piers around here use wood that makes the pressure treated stuff at the big boxes look environmentally friendly, and some serious SS nails. Both are incredibly expensive and difficult for the average joe to obtain...
kd4pbs
Likewise.
And I've recovered wood from 18th century structures - never seen anything but contiguous length truss lumber.
redneck joe
Haven't done it yet, next week when wife is in India I can play with the boat at the ramp.
tphoyt
The 50/50 ATF and Acetone works wonders and is dirt chep to make up. What ever you decide on start hitting now so its good and ready when you are.
cyclops222
Very dry threads. Super thin liquid. lights taps of a small hammer. Tighten and loosen nut very carefully many times without stretching the bolt threads. I have lost a couple trying.
Mc Tool
yeah , and a bit of heat ..... even if you just get it touch hot it still expands/contracts and helps whatever potion your using to penetrate
FLATHEAD
I can remember around 1944-46 helping my Dad straighten nails he recovered from packing crates. During WWII you just didn't go to the hardware store and buy nails. Didn't mind straightening nails as much as I missed having sugar for my morning cereal back then.
When I first got out of school I worked for a commercial contractor that would have us young guys pull nails and straighten them. When the box of straightened nails showed up on the site the lead carpenter would toss them in the dumpster. The contractor was so cheap when we roofed his sisters house we didn’t have enough tarpaper to finish. So he had us just take a 10 foot length and keep sliding it up the roof so it looked like we were putting it down ☹️.
