Best spark plug against fouling 1990 Evinrude 4hp.
cprodave
My Evinrude E4RESR has some degree of fouling that I would like to take preventive action against. Engine has been running Champion QL77JC4. I also see Optional plugs listed are QL86C or NGK BZ7HS-10.
What is a good (slightly hotter) sparkplug to replace the QL77JC4? I would think next hotter is QL77JC6. Or L77JC6 ( I don't need the "Quiet")? Or could I use NGK BZ6HS-10?
Any input will be much appreciated...
Honorary Supreme Mariner
Fouling is much ---" mis- understood "----Just use the factory recommended plug.
cprodave
Ok, subsequent to initiating this thread I found another thread that went into great detail and concluded exactly what you are saying.
Thanks
Sea Rider
Spark plug fouling is very notorious on 2 stroke motors, whichever HP they are. It's all about plugs not reaching their self cleaning temp which is achieved at + 500º C. Trolling motors will go that way, can install a next higher spark plug range, but will go that route. If a trolling motor will be used for that specific purpose, that's running at idle or fast idle rpm speed can use 100:1 fuel/oil ratio, but remember not to exceed those mentioned throttle settings or risk screwing the motor due to poor lubrication at higher rpm.
Happy Boating
cprodave
SeaRider ,thanks for this input. I have read similar recommendation from Leeroy's Ramblings except Leeroy advises Full Synthetic oil at 75:1. I suppose Leeroy's method provides somewhat better protection than 100:1 if occasionally operating at faster than trolling RPM's.
I agree with other inputs stating that fouling is a symptom of deeper RootCause/Fix other than going to a hotter plug. I wasn't aware that 500degrees achieves self-cleaning. That is good to know and takes some of the mystery out re: ideal combustion.
Working on this motor a bit yesterday I discovered a new condition/concern (motor "binding up" slightly at 2 rotational positions) so I will start a new Thread on that. Thanks again.
Would this slight ---" binding "----Have anything to do with flywheel magnets ??????
kbait
You have electronic ignition, which normally produces strong consistent spark. Make sure the coil grounds and ground from cd box are clean/tight. If you troll/idle a lot, you could open plug gap to .35” (.30” is factory spec). Fuel mix at 50/1..
oldboat1
I ran mine with the recommended oem plugs and gap, 50:1 mix -- always tried to clean it out a little running back to the dock. Easy motor to maintain.
cprodave
Yes it was rusty flywheel magnets (please see other Topic for update--now chasing a Fuel problem).
Thanks.
