So I bought a small used galvanized trailer for the flat-bottom skiff I've been building. I've put new lights on it, build and installed new bunks, and am getting ready to install new keel rollers. The trailer frame is in good shape, and I like the fact that it's a tilting trailer. However, the previous owner went and welded the coupler and the jack to the round tongue tube.
I'm not a welder, don't own a welding machine, and would rather not pay somebody to deal with this. What I'd like to do is replace the coupler, the jack, and the winch post - but I can't figure out how to go about it. The OD of the tongue appears to be 2.375". My thought was to cut off the tongue just aft of the welded-on stuff, grind it smooth, and then slide a new length of round pipe over the remaining tongue. Drill a cross-hole through both tubes, insert a long pin and clip, and then bolt on a new coupler, jack, and post.
Problem is, I can't find a pipe/tube that's got the correct ID to fit over the existing tongue, in either square or round. Wondering if anybody has any ideas here? BTW - reason for all of this is that the trailer isn't quite long enough for the hull, but I can't move the winch post forward any because of the jack stand - which is welded to the tongue. Secondarily, I'd like to replace the 1.875" coupler with a 2" coupler to match the other trailers I already own. One ball to rule them all.
