mark123456
Thread starter- Joined
- Jul 9, 2010
- 25
We have a BF 150 and it will run good for about a minute and then feels like it is going into limp mode but no lights or alarms are going off. It won't run past 1500. The pisser water never gets hot, should it? but does have a lot of pressure? There is a lot of water coming out from where the speedometer hose enters the lower unit, the hole is larger than the hose and a lot of water is coming out of there, is this normal? Water pump is new everything sems fine such as the water pipe, gromet etc.... The water hoses on the powerhead all get warm. The engine gets too hot to touch in the first few minutes but then cools down so you can touch it so the thermostat is working. I took them both out and tested in boiling water and they open and close properly. Thanks for any help
