WoodsHoleMass
- Joined
- May 31, 2011
- 2
This thing on my outboard leaks and will not support the motor in any position.
http://www.boats.net/parts/search/H..., VIN# BAMJ-1100001/SHOCK ABSORBER/parts.html
i can't run as is because I can't run the motor in the all the way down position, and even if I could it would kick up in reverse. Honda sells this part for $700, is there anywhere I can get an aftermarket version of this. Also open to any other solutions that will allow for shallow water drive.
Thank you.
Thank you.
