Jamesakers
Thread starter- Joined
- Jul 28, 2003
- 18
Before I begin with my problem, a bit of history is in order. I bought the boat with the motor about 4 years ago. The motor is a 1974 Evinrude 135 hp Starflite. First time out it idled rough and stalled. When I took it to the marina, a compression check revealed something had come loose and scored a cylinder. The marina (which has since went bankrupt) told me that they were going to bore cylinders and overhaul the engine, which cost a chunk of money. Since this repair, the motor has always idled very rough. Sometimes, out of the blue, I would lose a cylinder, only to get it back about 10-15 minutes later. Never could figure this out. <br />Now for my main problems. A few weeks ago, I found when the engine was warm, I would start the motor, and it would die when I gave it the gas. Upon inspection, I found that the timing advance under the flywheel was sticking just enough to kill the engine. After several cans of WD-40, it loosened up to where I could run it. However, the very next day, I heard a ping when I was running WOT. To my shock, I discovered that three of the four bolts that hold the carb intake housing in place had vibrated out, and I had sucked the lock washers through the engine!! I removed the heads, and found that (1) the marina had bored only one cylinder out to .033 over, and never even touched the other cylinders. (2) I found one of the washers welded onto the top of the one of the pistons, and had scarred the head pretty bad. I knocked off the lock washer, and dressed the surfaces with a file and emory cloth, and re-installed the heads. My compression was surprising even miraculous 145,145,138,152. When I fired the motor up, it runs very rough, and although the cylinder heads are cold to the touch, the flywheel is HOT! Also, it has practically no power. Any thoughts? My intuition tells me, that I have more than one problem. Could the pounding of the lock washer caused damage to a crank bearing, or something? Is it common to bore only one cylinder out and not the rest? Would this not make the motor run out of balance? <br />Any help at least where to start would be greatly appreciated.
