John3
Thread starter- Joined
- Jun 17, 2010
- 136
I replaced my original Mercruiser Outdrive (1967 160 Hp in line 6), Gear Ratio 1.65:1, with a used, pre Alpha OD 1.5:1. With my old prop 15.8 Dia X 15 pitch Wide Open Throttle, RPM = less than 3000, 0 vacuum on the gauge. I got a new prop 15 Dia X 11 pitch, tested it on the water today. WOT = 3100 RPM, again 0 Vacuum. Tests run less than a week apart, only me on board.
Seems to me there must be a problem in the OD, going from 15 pitch to 11 should produce a much better gain in RPM. The Engine seems OK, Temp & Oil Pressure OK, Vacuum Ok at idle. Today coming back the engine died in the no wake zone @ 1000 RPM, seemed to be laboring, started right up again. Could it be a LOT of friction in the OD? Shifts fine, no loud noises. I replaced the oil, there were fine metal chips on the magnet.
