benjaminok
Thread starter- Joined
- Dec 30, 2006
- 28
Hello all.
I have an older Big Twin 40 hp 1969 (40902R), which i am trying to rebuild & tune up.
Will change all ingnition parts & impeller, do a carb rebuild and overhaul & reseal gearcase.
As i am waiting for the kits & seals to arrive i have dismantlet the gearcase as i found quite a lot of water in the gearlube. Well the gear itself looks quite nice and now i am just waiting for the seal-kit.
This brings me to my first question:
1) My manual tells me to use a lot of different sealing compound, grease, Adhersive M and so on.
As i have none of them availible right now, what will i need to seal the spagetti seal, upper drive shaft seal & proppeler shaft seal ?
2) Manual says to use a mallet to remove the shifting rod gasket & O-Ring. Also it looks as it is has to go downwards to get out, according to the manual it goes upwards? Have not really god place down there, any good routines to drive this thing out? :% (it is driving me nuts!)
3) The waterpump has no seals at all, i noticed some blue sealing compound below and above the wear-plate?
If there is no seal, is it still necessary to seal the pump and if yes, what to use?
I guess thats all for now, thanks in advance, really appriciate all your help.
Best regards & have a nice weekend!
d
d
