sms986
Thread starter- Joined
- Sep 18, 2017
- 334
So thanks to a lot of patience and help from you guys on the forum, I have my 1963 big Twin up and running, sort of. I got it all together and took it out on my boat (longshaft transom) because the carpet on the boat I am restoring had not yet dried. The engine started fine, but it vibrated pretty strong at low RPM's. May be normal on an old motor, but it was much more "violent" than the vibrations from my 87 seahorse 9.9. Anyway, the other thing I noticed was that there was fuel leaking from the fuel filter. It was between a drip and a stream. So I left it choked for a bit to warm it up and shut the choke off. On the trailer, I ran it at full throttle for a few seconds at a time and it did just fine. Took it off the trailer and it didn't move very well (short shaft motor long shaft transom.) So I decided that when the carpet dried on the other boat I'd take it out again. That day was today, and today sucked. I started off same as the other day, choked it and let it run for a bit then shut the choke off. I started to play with the lowspeed fuel screw, closing it entirely and working it open. It would shut the motor off when closed, but when I started to open it I noticed no difference in performance, rpm, sound as I unscrewed it until it was practically out (9+turns). So I set it to about 1 turn out and put it in gear. I slowly cracked the throttle and it would get to the point where the throttle plate itself started to open, maybe a little further, and then bog down. I'd say about 3/4-7/8 throttle. When I backed off the throttle, I could keep the engine running fine. But every time I went past that mark it would begin to bog and eventually die out if the throttle was left all the way open. When I choked it, I could pull the throttle all the way out. No problem. I could even choke it, throttle out the whole way, and then turn the choke off and it would run for 2-3 seconds without choke at full throttle before bogging down.
Things I changed between the two runs: fuel filter diaphram and fuel line replacement, changed gas tanks, fresh gas mixed 25:1. I did notice that when squeezing the primer bulb, it never got to hard to the point it does on my other motor. I also noticed fuel leaking out of the inlet of the carburetor Venturi when priming, as if the needle did not shut. Note this.
Things I checked after second run: the needle seated fully when I turned the carb upside down and blew into the fuel inlet. Carburetor is IMMACULATELY CLEAN. Fuel filter and pump assembly is clean.
Note, the primer bulb is brand new.
Compression checked out at 90 psi in both cylinders before the initial start.
Fat blue spark in both cylinders as well.
I'm at a loss. I don't think the bulb is collapsing because the gas tank cap has a small hole in it where the vent is. I will check this. Also, the fuel lines have an inner membrane which I read on another post ended up collasping. It doesn't make sense to me that I can go up to 7/8 throttle before they collasping though. I have scoured the internet for a possible solution because I am at a loss and I am tired of making petty orders for one or two parts at a time, only to find that I need another part later on. The only things I've found other than the membrane collapse situation are "cleaned the carb, works great" or "primer bulb was collapsing." Any suggestions? Possible vacuum hose leak somewhere? Something more in depth? I am at a loss with this thing and walleye comes in in 3 weeks. Thanks in advance.
