baytonemus
- Joined
- Jun 23, 2010
- 217
The lower unit on my '63 Big Twin 40 appears to have been originally from an Evinrude (blue paint underneath), then put onto a Johnson (white paint on top), then eventually onto this Evinrude. It does appear to be a fit, however, and for the most part corresponds to what's in my parts catalog. The service manual says there are 16 rollers in the lower pinion bearing and I took 17 out of mine, but who's counting?
I'd appreciate some help evaluating the seriousness of the damage I'm seeing.
Propeller shaft oil seal housing retainer
This must have gotten twisted on the shaft at some point and has been planed down at an angle. However, nothing rides against this side of the retainer so it seems mostly cosmetic. I'd prefer to save the $40+ it would cost to replace this. I will if necessary, though.
Drive shaft grooves
These grooves appear to correspond to the top and bottom of the upper drive shaft to gear case bearing and are only on one side. I'm not sure what would cause this. Maybe that upper bearing is bad? The drive shaft does not appear to be bent.
Leaky gear case
My assessment of this is mostly based on the fact that the outside of the bottom portion of the gear case - below the seam where the upper and lower sections are screwed together - was greasy. (The photos do not show this.) I can also see a few remnants of a couple of different types of silicone near that seam. It seems to me like part of the problem might be that the screw holes are inside the gear case seal groove. So, unless the two parts of the case are perfectly flat (they're probably not anymore) OR the bottom of those screw heads really seat up tightly (they probably don't - everything is pretty dinged up), I could easily see where lube could leak through the screw holes. Would it be too risky to have the surfaces planed?
I welcome your collective wisdom! Thanks.
Drive shaft grooves
Leaky gear case
