Big wooden boat project [Splashed Sept 2017]
Ned L
You're welcome. Always glad to answer questions (to the best that I can).
I can't say I've caulked 'my share' of cast iron waste pipe joints, but I do know my way around them (and lead wool where you can't pour them). I've got a couple (or had) of those caulking irons too.
Pusher
That looks fantastic! It's amazing how many talents and skills are required to really be good at a trade. My generation just takes their stuff to a fix it man and /or the dump. No wonder we're all going in debt.
Cdubb2010
Fantastic stuff Ned! I joined the party wayyyy late here but it's great you are bringing her back to life. Returning a (big) old boat to her former glory is something I hope to do in the near future, makes it seem more do-able seeing others do it.
bansil
Wow, just wow!
Awesome job and for me a history lesson, i noticed you used masking tape on the wood before the black seal.
What would of been done before masking tape was invented ? A wax or?
Thanks
Tnstratofam
I am absolutely amazed every time I see an update here Ned. Thank you so much for sharing your knowledge and skills with all of us. The deck looks great.
Ned L
Wow, just wow!
Thanks
Before there was masking tape (and still today a good bit of the time) the seam compound was applied and afterwards the wood was simply scraped or sanded to reveal a fresh surface. I masked everything off because the teak is 60 years old and I didn't want to remove any more surface than absolutely necessary. Luckilly the cockpit sole had never been sanded much at all, so it is still probably 90+% of the original thickness. I wasn't so lucky other the foredeck, which is why I went with the "composite rebuild" that I posted very early in the thread. The death of teak decks is sanding and wear that makes them to thin to stay watertight and hold the plugs over the screws.
bansil
Thank you!
Makes sense, it still amazes me the cutting,scrapping and hewing of logs to make beautiful pieces of ART. .ugh i mean boats and houses of old
You are doing an amazing job of "retro-moding" her
(Please don't be offended by the last sentence, it is meant as a compliment)
Ned L
Thank you,.... and certainly no offense taken.
Oh,.... and 'single part curable' seam compounds have only been around for probably a little less than 100 years as well. Prior to that (and still on large or historic ships) a concoction of tar/pitch was used. That had to be heated and then dispensed or poured into the seams with a finned shaped ladle or dispenser, and then when cool the excess scraped flush. (Actually quite similar to how highway crews seal cracks in pavement today.). There is still a traditional deck seam compound available today called "Jeffries Marine Glue" that is heated and poured into the seams. The disadvantage of it in warm climates is that it will soften in the hot sun and become sticky (not what people want with their designer clothes today. )
One of the tough things about this caulking job was that the planks weren't tight together at the bottom of the seams (I had to use all those spacers), that made the cotton caulking job difficult, because at times there was a real fine line between "hardening up" the cotton enough and driving it completely through to the underside of the planking
GA_Boater
Ned - Did you apprentice under Noah? You're showing some old-time skills and she will be better than new! :D
sphelps
Great update as always Ned ! The caulking education will come in useful when I finally get going on the Wagemaker .. You'll need to guide me in the right direction on what to use and how to install on the rolled top cap .. I know down here I won't be using the Jeffries Marine glue ...LOL!!!
jennyo
HELLO NED . WHEN IS LAUNCH DAY.LOOKING FORWARD TO IT. I AM SELLING MY 22 FT OLSEN SKIFF DUE TO SOFT KEEL APRON. ABOVE STRUT. GOOD LUCK WITH THE LAUNCH BOB
Ned L
Thanks for the complements guys.
I'll be glad to offer any helpful advise I can for you Wagemaker.
Bob, sorry to hear about Roanne (I think I have her name correct), she's a really nice boat. You have mentioned her problem before, and I have actually thought that if I were closer than 200 miles I could take care of that for you,...
As for a launch date,............. stay tuned.
Magnolia_Resto
Amazing build. I'm about to start a 16ft. fiberglass resto, and already my eyebrow was twitching at the thought of a big wooden rebuild...
Ned L
Soooooooooo, I suppose as the expression goes, ................
All good things must come to an end
Ned L
and at some point you have to say to yourself 'enough is enough'.
Ned L
enhance
