Big wooden boat project [Splashed Sept 2017]
Grub54891
Thanks, I do work on mercruisers quite often at work. I just never get a clear answer from the manuals, or other opinions. I figured it would be fine, just needed a push to do it. Thanks again.
Not trying to highjack this thread, but just a quick question. So in my mercruiser,140, 1985 vintage, I can run the 160 thermostat as I only run in fresh water? Lake Superior.
yes
Ned L
Hopefully it is that time of the year to think about water instead of snow!
..... Been pecking along on a few things. I pulled the port generator off and took it to be checked out at a local place. He said it seems to be fine and it puts out, it might have gotten polarized backwards somehow. He's going to take care of that and adjust the regulators for both generators. It will be nice to have two working generators this summer.
The big project that I didn't get to before tossing her in the water was rebuilding the engine hatches. I have pulled off the hatches and taken them apart; again, carefully saving the original teak planks.
I numbered all the planks on the backside so I know how to re-lay them.
enhance
enhance
enhance
Careful demolition
enhance
enhance
And what I have left is a stack of teak sticks.
enhance
GA_Boater
Hope you're right about the snow, Ned!
The work never stops, does it? I know you will make something nice with those teak sticks. :smile:
Ned L
Then it was time to find some more sticks of mahogany for new frames...
Those two triangular pieces are 5' long, almost 2 1/2" thick and the widest is12" wide. .... Pretty good size pieces.
enhance
And with a bit of work I ended up with these.
enhance
the frames were epoxied together and fastened with #12 x 2 1/2" bronze wood screws. ....... I think they should last at lease as long as the original ones, which were spruce, nailed together with (hopefully at least) galvanized common nails. They lasted 61 years, so I don't thing I'll be touching these again.
(Sorry things are light on pictures, ..... sort of forgot to take them...)
I took one out to the boat for good measure to make sure it looked good.
enhance
Toss on a couple of coats of Rustoleum Gray
enhance
and we're good to go.
Then it's time to relay the original teak and drill for new #8 x 1" bronze wood screws (about 400 of them between the three hatches).
Again, I had to come up with a bunch of even thickness spacers between the planks for them to lay out correctly (cereal boxes are good shims lol),
enhance
Now it is time to cut lots of teak plugs, then do a bit of cotton caulking and apply the black seam compound
enhance
Ned L
I hope we're done with the snow (though it was snowing here just last week!). After all, she should be going back in the water in about a month.
I'm taking next week off to work on her and pretty much get her ready. It's nice that it is mostly just 'normal' annual maintenance now.
Watermann
Great work on everything.... but oh man you covered up that beautiful mahogany with Rustoleum paint :eek: :faint2:
sphelps
Awesome work as usual Ned !
ok so your using bronze screws ..
Did I do wrong by using SS screws on the Wagemaker ?
on the bottom of transom ..
Sea18Horse
Greetings all! Been away from iboats for a number of years. I was somewhat active on the Johnson & Evinrude outboards forum and had a project going on this forum that embarrassingly has stalled. But I must say this thread and this project has been a huge inspiration for me in a new, much more modest wooden boat project I've started. A 1965 26' Owens Flagship. 002_small.jpg So a big thanks to NedL especially and the rest of the gang for the inspiration, insights and information contained in this thread.
I plan to start a thread on my own project soon.
Cheers...................Todd
Ned L
On your Wagemaker I really see no problem (as I believe you will be keeping her dry on a trailer most of the time).
S.S. does have the disadvantage of being prone to crevice corrosion. This is a type of corrosion that takes place in anoxic environments, typically in wood below the waterline where the moisture content is consistently very high.
In a small boat I rebuilt 40 years ago I used a few 1/4 x 20 bolts in the bottom, when I removed them about 10 years ago some were corroded more than half way. You could break them in half with your hands. — That boat stayed in salt water during the summer for a couple of years.
For this reason bronze is really the accepted material for below the waterline.
Again, I see no problems in your future.
Ned L
Greetings all! Been away from iboats for a number of years. I was somewhat active on the Johnson & Evinrude outboards forum and had a project going on this forum that embarrassingly has stalled. But I must say this thread and this project has been a huge inspiration for me in a new, much more modest wooden boat project I've started. A 1965 26' Owens Flagship. So a big thanks to NedL especially and the rest of the gang for the inspiration, insights and information contained in this thread.
Your Owens is a real practical little cruiser, nice looking boat!
What engine is in her? The Owens “Flagship”?
I’d love to see more pictures of her and will look fowrard to your thread.
Ned
Sea18Horse
I’d love to see more pictures of her and will look forward to your thread.
Ned
Thanks guys, Having fun unraveling the mysteries. yeah it's a Flagship engine. Small block Chevy based. My research indicates for a 26' it could have been the 195 hp 283 or the 225 hp 327. The long block's been replaced so who knows what it is now.
sphelps
Thanks for the reply Ned I always appreciate the good advise !
Ned L
For a quick catch up, ....
fastening the teak down
enhance
With lots of shims for spacing, ......It must be nice to work with new teak planks, where you cut them to size and don't have to worry about the 60 years of dimensional changes. lol
enhance
Then it was time to cut a few plugs, ......... just about exactly 400 for these three hatches
enhance
enhance
Then set them in the screw holes
enhance
enhance
enhance
Trim the plugs, give the them just a very light sanding to take off the highest spots (now that everything is fastened solidly again), and get on with the caulking.
enhance
And the usual seam compound treatment.
Lots of masking tape and mess. :D
enhance
enhance
and the finished result. ...... I know it doesn't look the greatest, but a bit of sunlight and some gentle washing and they will blend right in with the cockpit sole.
enhance
89 resorter
I think that looks great .... can't wait to see pics of it in the boat!
