bigger wire on troller?
procraftmark
I have the standard bassboat setup with my 12/24 troller plug in front ,and it looks like I have 10 gauge running the whole length , I am running a 24 volt system , if I replace the wiring with say 6 gauge will It make a noticable difference in power?<br /><br />thnx<br />mark
petryshyn
Re: bigger wire on troller?
This is a very subjective question pending on several factors. Take 2 voltage readings while trolling as shown below. If there is a difference of more than 1 volt between each meter, then its worth increasing the wire size.<br /><br />
roscoe
Schematic, you got the coolest diagrams! :)
Boatist
ProcraftMark<br />I agree with Schematic. I would add, when doing check have your trolling motor on it highest setting. Another way to get an idea if it might help is to compare size of wire to trolling motor itself with size of wire to battery. Voltage reading the best way. If you do change it I would suggest useing marine wire.
bassin51
I changed my 12v troller from 10 gauge to 4. It was well worth the time and money. It seems like it almost doubled the time between charges. I bypassed the plug, hard wired directly to motor.
Boatist
Mark<br />Thank for coming back with the info and results.
petryshyn
Just for informations sake, wire size is more critical for a 12v troller than a 24v unit. :)
sergioy
where can I get some of this 4 gauge wire? I had a hard time finding 10 gauge. :eek:
Stumpbumper
Why not try just adding a second 10ga wire and connect both instead of a single 4ga.<br /><br />Terry
procraftmark
sorry boatist , it looks like the wire on the t/m is bigger than the wire to the receptacle it appears like the boat wiring is 10ga. but I am not sure. <br /><br />mark
buttonhook
go to where they install high powered car steroes to get the bigger wire, they would prob. run it for you.
tscott
4 gauge has more ampacity than 2 10 gauge wires paralled. The bigger the wire size, the less resistance,therefore the less amperage.<br /><br />Your 10 gauge was probably getting hot.Any trolling motor over 45lbs. thrust should use 6 gauge at least.<br /><br />The less resistance,the less heat, the less voltage loss.<br /><br />Tom<br />P.S. I'm an electrician by trade.Wiring is once thing I know about.Still learning about boats. :D
