bigmacdaddy1967
Thread starter- Joined
- Jun 16, 2010
- 3
Ok I'm at the end of my rope. Help! I have a 1987 johnson 70 hp motor. The high temp alarm is going off at high rpms. I've replaced the water pump and the thermostat and both are working fine. But the high temp alarm is still going off. I took out the high tem senor and there is no alarm with out it but I don,t want torun it that way. I tested the sensor in a pan of oil and with a thermometor and the sensor is closing at 197 degrees and it opens back up at 163 degrees. Accordind to my generic manual it should close between 205 and 217 degrees so it is a little off. However its a generic manual! I can run the motor all day just below or at slight plain with out the alarm going off. Is it possible I have a flaky thermostatic switch? Help
