Re: Bilge outlet placement
I don't think the placement fore or aft is much of a problem. As far as the height as high as possible without making it difficult for your self. My only caution is not so low as to allow water to enter the boat with a heavy load.Years ago I bought an old Garwood boat that had an auto bailer
would draw the water out a syphon at speed.It had a knee to keep it above the water line.
The po loaded a big gas generator aboard to be taken in the morning for repair.They found it sunk in the morning.
Thanks, Steelspike. It is a Harvey dory with lots of reserve buoyancy due to hullside flair so it will take a lot of weight to make it squat. My biggest concern, as I understand it, is that the higher you pump water, the less efficient the pump becomes. That said, I've got at least 20 inches of clear space above waterline to work with before I get into built in storage, gunnels etc. My 1st boat and you'd have to pack for an expedition to find someone with less knowledge/experience than I have. Thanks for the help!
