jcintheville
- Joined
- Aug 4, 2008
- 11
Last couple times I was out, last fall, the bilge ran constantly. I thought it was the panel rocker switch, so this weekend I changed it. That did not solve the problem. The panel switch seems to be wired correctly but it just continues to blow the fuse at the panel box. The only way to shut off the bilge is turn off the battery. When I looked at the bilge I noticed the float switch had come loose from the harnass and was laying on its side next to the bilge.
Could the float switch be bad and would that cause the bilge to be stuck on? I just read a couple threads about a fuse in the battery feed. If I disconnect the fuse that should shut off the float. Am I looking in the right direction? Or do I still have a rocker switch problem?
Boy, boat wiring is a world of its own. jcintheville.
