platinumedge
Thread starter- Joined
- Aug 12, 2018
- 106
Good Afternoon Fellow Boaters,
I'm winding down the repairs to my 1994 Four Winns Sundowner 215. It was left outside (in Maryland) for several years, so a lot of things that were submerged needed to be replaced. One of them is the bilge pump. I replaced the old pump (Attwood Guardian 500) with an Attwood Sahara S500.
The wiring is actually pretty straightforward. The real question is this: Whenever I apply power to either (or both) input wires (not the ground!), the pump runs?! If I apply power to just the 'automatic' input, the pump runs. And it runs whether the float is up or down.
This is the first time I have tried wiring the pump. So my question becomes, is the float valve stuck/defective?
It's certainly usable as it is, because I normally keep the boat inside my garage. And I can just pull/insert the fuse when I'm out at sea.
Any input or recommendations from you guys is, as always, greatly appreciated!
Cheers,
-- Jeff
Cheers,
-- Jeff
