- Joined
- Jul 18, 2011
- 19,646
My bilge pump bit the dust during one of my recent outings with the boat. I accidentally left it on while anchored and it seems to have burnt out the motor. When I checked on it this past weekend, I noticed that there was an indicator light illuminated inside the instrument panel switch that would not go off no mater what I did . . . battery on/off . . . did not matter. So, that got me to wondering about how the bilge pump was wired and if there was some sort of short in the switch. My thinking was that light within the switch would/should only go on when the instrument panel lights are turned on. The light within the switch stayed on no matter what.
Then, I came across this wiring diagram which made sense as to how the light stayed on . . .
Based on this diagram, the indicator light within the instrument panel switch must also be connected to the outgoing power lead of the switch, and also the float switch wire and the instrument wire must joint at the voltage side of the bilge pump. That way, if the bilge has enough water in it to activate the float switch, which it did, then the instrument panel light would go on, as an indicator that the pump was running.
I ended up disconnecting the ground lead at the switch, switch made the indicator light go out, so as not to run the battery down. I subsequently pumped out the bilge by hand, which probably would have made the indicator light go out as well. I had just never seen a bilge wiring & switch setup like this, but maybe never noticed, since this is the first time I had a pump fail.
I think I got to buy a new pump . . . the old one is a Rule 2000 GPH.
