bilge pump
vnsnol
Hi today when I was out boating the bilge pump came on a lot and a lot of salt water was pumping out. This has never happened before. Where is the water coming from and how did it get there? Thank you for your help.
BoatAddiction
Re: bilge pump
Tell more about the type of boat. Fiberglass hull? Is she a sterndrive, outboard, or inboard? What types of thru hulls do you have?
fishinrado
Re: bilge pump
your boat must have a constant electric bilge float. it comes on just like a float in a basement well that operates the sump pump when it becomes full. u either have been accumulating water little by little and the float reached the point of turning on or u have a new big leak........post more info. did it stop? kept coming out? etc... hopefully for u it stopped.
rndn
Re: bilge pump
Need more information if it's an I/O maybe your fresh water intake hose sprung a leak??
Re: bilge pump
Unless You can Look in the bilge,+ See where it's coming From,......
You need professional Help,+ Now.......
Rust will cause All Kinds of Problems,....... Quickly...............
