Bilge pump
widegld
Does a 1984 Beachcraft runabout come stock with a bilge pump? I can't find one but there is a square hatch in the floor between the seats.
Alumarine
Welcome,
If it came standard with a bilge pump or not a lot of things could be added, discarded or broken in 37 years.
You'll have to look around to be sure.
mike_i
Do you see a water discharge somewhere on the hull above the waterline most likely near the stern? Is there a fuse panel? If so if not marked are there any fuses not accounted for, same with switches. Last resort is to start filling the bilge with water and see what happens, do this on land.
