ken52
Hope this is the right spot for this question. If I install a bilge pump with an 1 1/8" outlet and use a reducer for 3/4" hose would this damage the pump? I figure the GPH will be reduced some. There was a Rule 800 in my boat but it won't push the water. Everything seems clear, pump runs but water barely moves 6" up hose. Figure I'd put in a bigger flow rate pump while I was changing it out.
Fireman431
Re: Bilge Pumps
More than likely the impeller was slipping on the little metal shaft. Happens a lot when bilge pumps either get too old, too brittle, or too hot. Reducing the diameter of the tubing will decrease the water flow a bit and increase the pressure a bit, but it should still run just fine.
ken52
Re: Bilge Pumps
Thanks Fireman. Might be just as easy to update everything to the 1 1/8" while I'm fixing it anyway.
Fireman431
Re: Bilge Pumps
True, as that's what it was designed to do. or go with a smaller GPH bilge pump and stay with the 3/4-7/8" hose.
jhebert
Ensign
Re: Bilge Pumps
Pumps are typically rated for output flow rate with two specified conditions: lift and head.
LIFT is the vertical distance a pump will raise water into its intake. For most centrifugal pumps lift is rated as zero. That is, the pump cannot lift water into its intake, and the pump must be immersed at the bottom of a sump so water flows to the pump intake by gravity.
HEAD is the vertical distance a pump can raise water on its outlet. The greater the head distance on a pump, the lower the pump output.
The diameter and design of the hose on a pump outlet will affect the output flow. Hoses with a corrugated inside diameter reduce flow. Of course, reducing the size of the hose reduces pump output.
The rating of most centrifugal pumps sold as "bilge pumps" is extremely optimistic and represents the optimum situation: zero lift and very minimal head. As you increase head the pump output will rapidly decline, until at some point it reaches zero if the head becomes too tall.
ken52
Re: Bilge Pumps
I've been replacing all the hoses from the fish boxes and bilge from the corrugated type to straight wall hose.
Fireman431
Re: Bilge Pumps
A bilge pump is like paying for insurance. You better have it and hope you never need it.
ken52
Re: Bilge Pumps
Thanks for the help guys.
ken52
Re: Bilge Pumps
Just ordered a Rule 1000, I think that should handle the job well.
