Bilge: to paint or not to paint?
Cougar_15
As I'm going through my (seemingly endless) list of things left to do on my boat I started thinking about the bilge. The question is should I paint the fiberglass in the bilge area and if so what is best to use. If I'm going to paint it I need to do it before I glass the new deck in.
So I though I would see what the popular opinion is regarding bilge painting. Is it necessary to paint? What paint is best?
This is for a 15ft tri-hull that will be trailered and garage keep most of the time but may be in the water for a week or more on occasion...
PiratePast40
Re: Bilge: to paint or not to paint?
I painted mine with Zinzer oil based primer and then finished with a high quality epoxy enamel. I think it looks pretty sharp and very durable. Just make sure you leave enough time for all coats to cure completely.
legoman67
we painted ours with interprotect 2000E. it looks great when clean..(clean+bilge do not go together for too long)
Cougar_15
I've seen interprotect 2000E recommended a few times on the web when I searched for bilge paint. What kind of prep did you have to do? How was the application?​
Has anyone tried using Epoxy Garage floor paint in a bilge? Something like this (from home depot)​
A high-performance, ready-to-use, water-based floor paint that resists hot tire pick-up and marring. The finish is highly resistant to chemicals, oil and gasoline, which reduces the need for maintenance of hard-to-clean interior or exterior floors. Available in custom colors in a Satin Finish.
legoman67
we just did a quick sand with 60 grit, then acetone, then apply. the stuff goes on really thick, and the recommended coats on the side of the can is silly. We did 3 fairly heavy coats and its good.
We used 2 and 1/2 gallons for ours..
shortly after the last coat
image.php
allpoints360
Paint your bilge white.
You can see things you need to see.
Good luck!
fishseeker
Good luck!
Boy ain't that the truth. My project had a BLACK bilge.(factory cause the transom was black also) How you suppose to see an oil leak?
D.spencer
I painted my bilge with white gel coat- it is very easy to see in there and of course, very durable.
jonesg
interlux bilgecoat paint, high quality paint, it draws the moisture out of the wood and glass. Brushes on like sour cream.
