Re: Bimini bouncing around?
I had same issues when I first installed mine. I had to use the universal mounts (the ones that allow mounting to angled surfaces) up front because of the side windows. What I did to control the sway is as follows.
First, I used all stainless steel connections and mounts in combo. w/ rear aluminum support tubes. I made absoultly sure the mounts are square w/ each other. I used a rubber pads under the mounts between them and the gunwale to prevent stresscracks in fiberglass/gel coat.
Second, made the front strap mounting loc. more twords the inside of the boat as seen in the pic by the bow window walk thru. I also made sure when the straps are tight they are exactly the same length and when straped down they are flat and have no slack in either end of the loop that goes around the bimini frame.
Third, when top is folded back and covered I use the same front straps in combo w/ another set of straps criss/crossed over each other to form a "X" and attach one to each cleat at the rear of the boat to hold it steady
I can do about 50 mph on water before stuff starts getting out of control. Almost 60 on a calm day. If i am going to trailer over 45 mph I lower the top (forward due to windows) and use same straps and front mounts to tie it down.
