black max idle
jigmister
86 175hp
got her running real nice with new reeds and carb rebuild
Idle is sometimes perfect. Other times it is kind of crappy. In gear lugging in a no wake it can start to spudder and cough.
I have to give it just a bit of throttle and then it clears out for a bit but goes right back to its coughing.
Not always just about half the time.
I chucked the idle stabalizer a year or 2 ago when it took out nearly all the other igntion componets.
Is this somthing I will just have to live with or can I try to adjust the timming? I have it set at factory 14 before topdead center.
thoughts?
jigmister
Re: black max idle
no comments?
anyone have information on the anti detnonation device on this thing?
aussieflash
Re: black max idle
Still sounds like problem with reeds.Did you replace reed block Gasket.Float level been reset to spec?
jigmister
Re: black max idle
yes and yes. I do not think the reeds or gaskets are a problem.
what exaclty causes the engine to sneeze? lean, rich, cold or?
aussieflash
Re: black max idle
86 175hp
thoughts?
I hope you meant 14deg ATDC pickup and 18deg BTDC max timing.
aussieflash
Re: black max idle
Also check compression,spark,bleed line routing if timing is correct.
If you didnt use new reed block gasket,then get one.Good Luck
Paul
jigmister
Re: black max idle
yeah I meant ATDC. I will look closer at the bleed lines.
Thanks for the help
