Black Max this is a tough one???
imported_HOSSS2
I recently bought a 1984 Stratos with a1984 Black Max 150 hp.It started running real rough & flooding. Would not get over 30 mph.I decarbed with deep creep spray & in gas.I changed plugs ,Champions because thats all i could get at the time.Sounded pretty good on muffs.When we put it on the water there was no power,would not plane.No speed at all.I took boat to a local boat shop .They have changed check valves for oil gas mixture,fuel line was 2 sizes too small.Replaced that.Flushed oil & gas system.Checked compression which was close to perfect.Rebuilt carbs.They put in good plugs.I talked to mechanic today & he said he had one more test to run.He was going to check the stator.Boat checks perfect in shop ,runs good ,everything says nothing wrong.They take boat to lake & it will not plane.The guy says he has been doing this for 10 years & never seen anything like it.Any help or ideas would be appreciated.
pipes0000
Re: Black Max this is a tough one???
could be a spun prop???does it rev clean with no go? or just no torque
studlymandingo
I assume they have checked for spark on all 6? The reason they are checking the stator is because there could be a winding bad in the stator which would cause erratic spark at high speed.​
imported_HOSSS2
prop has been checked. no problem there.starts to rev then cuts out & does not want to run.throttle back & it will try to die.yes they have checked spark.all good.would bad stator only show up on the water & not in shop.
WillyBWright
I got vexed by a semi-bad stator once. Landlocked facility, ohms readings were not that far off spec and DVA readings cranking showed good. But it broke-down under real-world conditions. Customer couldn't get full speed. It ended-up being the stator, but it could've just as easily been a switchbox.
The stator has separate high and low speed windings to each of two switchboxes.
The switchboxes combine and convert the voltage from the stator to produce voltage to the coils.
If the stator has a partially failed winding, one switchbox doesn't get the necessary voltage to produce high-speed spark to up to three cylinders.
But if the portion of the switchbox that processes that voltage from the stator has a problem, then the fault lies with the switchbox.
I was always told that ohms specs were ballpark figures and this one was just barely outside of the ballpark. But enough to cause the problem. Replaced stator, problem solved. No guarantee it's your solution, however. It could still be a switchbox. (In the vast majority of stator failures, one or more winding(s) shows no resistance at all rather than slightly out of spec which was what did me in.)
Testing DVA output from the stator and resistance readings must be considered in tandem and I think that's where your answer lies.
If the repair facility is fortunate enough to be on-water, the problem can be seen with a timing light. Some cylinders would lose flash at high speed. If the switchboxes are swapped, the problem will travel with the switchbox. If not, the problem lies with the stator. (The stator leads would have to remain with the inside/outside switchboxes as would the coil leads. Your mechanic should understand this. One set has yellow tubes, the other set does not. Yellow-tube leads go to the outer switchbox. Feel free to print and share. I hope it helps, and I hope it's not as totally confusing as it was to me at first.)
