DunbarLtd
Thread starter- Joined
- Nov 8, 2016
- 357
Good morning folks. Yesterday I removed the lower unit to get ready for the summer, replacing impeller and noticed black oil on the inside of the water tube that goes up to the head. Upon inspecting the innards of the leg it appears the water tube can be exposed to exhuast fumes. I am going to assume finding oil at the bottom of the cooling tube and inside the cup (where the tube inserts) of the water pump is normal? It does appear to be combusted fuel and almost black in color. definitely NOT gear oil. I pressure tested the unit before removing the water pump and there are no leaks.
1988 85HP Force 3 cylinder
