Re: Black Spark Plugs
I pulled this one out of my 90hp Ocean Pro oil injected carburetor motor today to show you. All 4 plugs look the same. Plugs were new this season and have around 120 hours on them and anti-seize grease on threads. The old ones were 2 years old and looked browner but not black and sooty. I run Sierra premium blend oil through the reservoir tank, no stabilizer, regular pump gas in a 12 gallon portable tank and get 65-75 miles per tank hauling 900-1000 lbs passengers & gear @4000rpm cruising around 35mph typically on smooth salt water. Very light glass boat just under 16' similar to a Whaler hull but lighter, top speed is 49mph @ 5300rpm with me alone in it on a 13x19 SST1 prop. This oil injected motor averages about 80:1 fuel/oil ratio based on consumption.
I would back down on the oil if you are pre-mixing, definitely don't use more than 50:1. But if your motor sounds like the video motor, you have other problems. That's a cylinder dropping out.
