rjcamel2355
Thread starter- Joined
- Apr 22, 2015
- 236
Have you replaced the fuel filter and done a fuel pump kit yet?
Also, you did a link and sync after you put the carbs back on?
Yessir, I did a link and sync, I have also replaced the fuel filter, and did a fuel pump kit.
I started another thread, due the having a "Running out of fuel while at WOT" issue. If I just drive around 3500-4500rpms, then it doesn't happen, but if I open it up WOT and hold it open for about 300 yards or so, it'll start to bog down and I'll have to return to idle pump the bulb back up and take off again. If I try pumping the bulb while at WOT, it'll suck the bulb flat, and there is no pumping it back up.
Was told to check the anti syphon valve, and check the fuel tank vents and/or other areas that could be causing fuel restriction.
