roscoe
Thread starter- Joined
- Oct 30, 2002
- 22,000
1996 Chevy Blazer
Factory am/fm cassette 6 spkr system.
Rear door spkrs didn't work when I got the vehicle.
Drivers door spkr died a year ago, then would occasionally work, until last fall.
Ok, decided to throw in a Sony cd receiver, bought it from Crutchfield and received all the necessary plug in wiring harnesses.
Installation went without a hitch, even though GM made it more difficult than it needed to be.
I now started on my journey to locate the speaker problems/gremlins.
I pulled the two rear door panels.
Examined the speakers and wiring, all are intact, no water damage, rubber boots from door to body post are intact. The power windows and locks all work, and all share the same boot, so things should be good there.
Where else do I look?
Is there somewhere under the dash where the spkr wires from the stereo harness, plug into separate harnesses for each door/speaker?
Or is it one continuous wire from harness to speaker?
If not, where do I look?
Any and all advice welcome.
