Block Leak
AndyJo
I recently purchased a 1997 boat with the V-8 350 engine. I realized today that I have a weeping leak about 2" about the right side block drain. There is a stain on the block where it has been leaking. when you dry it off you immediately get a drop of water that appears and runs down the block. I also noticed on the other side at the same location that it is stained but doesn't appear to be leaking. Any thoughts on this problem and what should be done would be appreciated. Thanks
Re: Block Leak
Ayuh,... Welcome Aboard....
You can let it rust shut, or maybe epoxy it....
No water in the oil,..??
AndyJo
Re: Block Leak
I don't see any water on the dipstick. It is just seeping out right now but didn't know if this could get worse and what should be done about it. Thanks for any help.
JustJason
Re: Block Leak
You should get an inspection mirror and see if you can pinpoint that leak. It could be the block, the head gasked, the manifold, etc etc...
AndyJo
Re: Block Leak
It is definitely the block. It is about an inch below the head and you can see the rust streak down the block beginning from that point. On the other side there is a rust streak at the same location but doesn't appear to be leaking.
Re: Block Leak
Ayuh,... It's a Freeze Crack,... Run it til it becomes a Real Problem,...
Then, replace the motor....
twostroke87
Re: Block Leak
If its def coming from the block then its for sure a freeze crack. What you could try, and I've seen it work sometimes and other times it doesn't but it is worth a shot. Dry off the area, and marine tex the crack, let it set and dry, then sand it flat/flush. If it still leaks then atleast you tried. I've noticed it works best if you drain the blocks and manifolds, let it dry and bit you don't want the area to be wet. Get a heat gun down there if you have to and evaporated away any water. Mix your marine tex of choice color (i like black) and lightly coat over the crack about 1 inch around it. If the crack is deep and wide, like a gash don't stuff the marine tex in, just lightly fill it. Once its dry, sand it down and paint over it with mercruiser black engine paint.
When your done if the leak has stopped, congrats keep an eye on it and check it to see if its leaking again every once in a while.
If you do all this and it still leaks, oh well atleast you tried. Run it until it becomes serious. If your running in salt water hose it off with fresh water too keep corrosion from making the leak worse.
AndyJo
Re: Block Leak
I did a closer inspection today with a really good light and found that this motor was previously repaired on both sides.The color match to the engine paint is almost perfect and it was sanded very good to blend in.
So unfortunately I've inherited someone elses problem and poor maintenance. I guess this is the bad boat experiences that I've heard of but have been fortunate not to experience in my 30 years of boating. I've had some $500 problems but nothing to this magnitude. It's a shame that people have to sell stuff like this but unfortunately that's the way it is. Maybe someone knowledgeable should come up with a boat buyers checklist to hopefully keep people from getting screwed.
I'm curious how you avoid this on purchasing a boat? Can the engine be pressure tested? There's a lot of places that you could have a crack that you would never see.
Well tommorrow Ii'll be contacting the local boat shops to find out about putting a block into this thing. Unfortunately I paid NADA average retail price for this boat so I'm going to have way more in it than what it's worth.
Thanks for everyones input and helping sort this out.
Mercury13
Re: Block Leak
I'm still in the evaluation phase of a problem like this. When I ran the boat with muffs for the 1st time after dewinterization, I saw the water running down the block. I shutdown and saw the crack. 4 inches long. I asked around a little, read on the internet, and this forum. First ground the area, then industrial degreaser, ready to apply JB Weld, when the machinists recommended Devcon Titanium. So I did the job with that and 5 runs later it's still holding.
If it gets you through the season at least you'll be prepared for the expenditure next year.
Steve
Mercury13
Re: Block Leak
Ayuh,.... You said it's a Damp spot....
Unless that $10, $12, Grand is burning a Hole in your pocket,... Go Boating,.. Have Fun...
An epoxy repaired block is Not the end of the world,...So long as the Oil stays Water-free...
